3P Charging Adapter: Charge 3 Batteries at once
Hi Everyone,
We just wanted to let everyone see a new product of ours, have more fun and get a 3P!; http://nukerc.com/3p-battery-adapter-ch ... tom-2.html
Stop waiting hours to just charge one Battery at a time. Connect 3 Phantom2 Batteries and charge all at once..
This 3P Battery Charging Adapter Board is designed to be fully-compatible with your current version DJI Phantom 2 Charger, or other After-market charger. The integrated circuit inside the battery will automatically stop charging once the Battery is full so no worrying about if one of your Batteries is too much charged than the other
This 3P Parallel Charging Board is suitable for use with the original DJI charger or other aftermarket Li-po Chargers.
*Check out our Phantom 2 Battery Clone Product Page to see more details about our Batteries, $72.99; http://nukerc.com/phantom-2-clone-li-po-battery.html
How would you connect this to a normal lipo charger? And which settings should I use? Thanks!
A normal LiPo charger won't do much good and may damage the phantom battery, depending on what max voltage it sources when in CC mode. You need a 12.6V regulated source to fully charge the phantom battery. A Pb battery charger could give you a max voltage out of 13.6V
Or use this one from E-bay...
Plugs in to the P board no problem....
Charging time may extend...
intertronixlabel
