32 Channel on Samsung Note 5 (android)
anyone have it working with all firmware updates? No dice for me. P3Pro and Note 5. Don't know what I am doing wrong. :confused:
I know that's got to be true. I just cannot figure out what. I suck.
How did you do it? Under the comments section of the below video, there are instructions for both Android and iOS.
Btw, if you view this post from a mobile device, you can't see the comments section. You need to view it from a computer.
I have iPad Mini and hack still works with the latest Go App 2.7.1
A very common issue with Android users who are having trouble is that they put the file in an incorrect folder. Perhaps that's whats happening.
Be careful to copy the file to the root of \Android\data\dji.pilot\files on your device.
Reactions: JoBe
Here are the full instructions copied and pasted.
Download 32 Channel DJI Config File file here. The downloaded file is in RAR format. You need to use a compression utility like 7-Zip to uncompress it.
www.rcgroups.com/forums/showatt.php?attachmentid=8124074&d=1438817912
If you have an Android device, do it like this:
1.Connect your Android device to your computer
2.Download the file named .DJI.configs
3.Copy the file to the root of \Android\data\dji.pilot\files on your device
4.Launch the Pilot app and you will see that the remote controller now shows support for 32 channels
For iOS devices:
1.Connect your device via iTunes
3.Click ‘Add File’ and copy the file to DJI Pilot Documents
4.Launch the app and you will see that the remote controller now shows support for 32 channels
That what I think I did but I must have botched it somewhere. will retry it.
Just tried and it works! Dang it's shockingly easy once you get the right file (had to Unzip the RAR).
The iTunes route is so simple it's almost scary LOL!
So now a bit deeper question.... when I go into Custom do I simply pick the channel that's the cleanest and go with it and leave it? Or do I need to monitor and change channels on-the-flly?
Thanks in advance.
Allen
Can someone post it here as an attachment or mirror the file?
Yep I spaced on that one. Although I see it was edited 8 min ago ;)
