3 pin cable that connects to gimbal transmitter
Re: 3 pin cable that connects to gimbal transmitter (fpv ?)
Is this on a Phantom 2 or a Phantom 1?
If it's a Phantom 2, then the cable is already installed in your craft, you just need to follow the wiring diagram in the Phantom 2 manual and solder the appropriate connections.
If it's Phantom 1, then you should have a 3.5mm cable that connects to your GCU. This has 3 wires in it. Ignore the red wire and connect the other two to video and ground for your video transmitter. To power the video transmitter you will need to solder on to the aux power connector.
ODIN Reviews
