2 questions.
Leeds West Yorkshire UK
1st Why are there 2 8pin socket's on the H3-3D gimbal. What are they for.
2nd Who has the gimbal hitting the plastic mount pin's on the bracket when the gimbal tips left and right. I tilt one way and it hit's the bottom of the mount pin.
Is this easy to correct.
Looks like you can use the other 8pin port with this cable. That is if you want a solderless plug n play cable for FPV and iOSD without using the ribbon usb connector.
The mounting safety pins, you only need two of those diagonally. You can remove that one that hits the gimbal, and just have two pins, one opposite side front, and one diagonally across at the back.
Or remove those pins and use small cable ties instead. Those pins can only be used once, most people ditch them and use cable ties.
