- Joined
- Aug 12, 2014
- Messages
- 8
- Reaction score
- 0
So, initially I had the 'common' problem of the X1 lever on my TX not making contact with the actual variable resistor on the circuit board. The lever wasn't doing anything, no response on RC assistant software or the main software. The resistor was smashed into the board. So I gently pulled it back out to where it should be, aligned the resistor's screw with the screw from the X1 lever, and then put it back together.
Now, I actually do get some response from X1 with the movement of the lever. The problem, is that it will not correctly configure. It goes from fully down tilt (-1000) all the way to fully up (1000) with BARELY any movement of the lever. This is impossible to get the gimbal tilt to work right, it's either going all the way up or all the way down. The lever moves maybe 5% of the way, and that is enough to make the X1 signal go from top to bottom, and the other 95% of lever movement doesn't do anything. The configuring doesn't do anything to help this. Can't use the X1 for now. I contacted DJI but no response yet.
Is there something I can do??
:x
Running tarot gimbal, v1.08. Just want tilt to work right, gimbal operates fine.
:x
