What I want to know is exactly what the three wire going to the YAW (Black, Grey, Yellow) control, and the Aileron (Black, Grey, Yellow) do. Are they +,- voltage being returned to the board, etc.?
Inside the controller, each of the controls has three wires going to them. Yaw (left thumb) and L/R(right thumb) the wires are Black, Grey, Yellow. The Up/down and the Forward/Backward are Brown,Red,Orange, but those I will not need.
I see a 3.3v between the gray and Black, and gray and Yellow. But the voltage doesn't change when I move the stick...
The colors don't mean much without a drawing or photo so try this: Measure the center leg or terminal of the potentiometer referenced to vDC common return, i.e. negative (-), ground, etc. when moving the stick(s).
The voltage drop across the two outside terminals will remain constant (3.3v you mentioned ?).
The voltage at the center terminal will vary when referenced to ground or either end terminal.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
