N017RW
Premium Pilot
IMO, the only function the parabolic reflector does is to block other unwanted interferences around the RC's antenna. Yes, it does boost the signal, but all it does is to reflect noise towards the AC, so, it's only boosting noisy signal.
This is becuase there is a gap of 1-2 cm between the reflector and the anetenna, which is enough to throw the reflected signal out-of-phase from the direct signal transmited between the Tx and Rx. (Out-of-phase signal = noise).
I think it really depends on where you are using it, it's probably more effective in an urban setting than in the middle of wilderness.
The focal point (or in this case 'plane') is a function of the parabola's dimensions. It is independent of the frequency (wavelength).
GENERALLY all r/c antenna systems are subject to multi-path and some use this to their advantage with spatial diversity and/or MIMO configurations.
