Wind surfer Antenna mod
Just wanted to ask if the wind surfer antenna mod is Wirth it or will it damage the controller?
Will it increase the the range?
Thanks .. Ps. Dji phantom 4 series leaked photos shows a larger battery slot- increased flight time maybe :)
yes it helps cheap way to get better range had one now installed argtek
Great- I will try this out and then do the argtek
I just installed the argtek a couple days ago - haven't flown with it yet due to weather - hope it helps. Took me about 30 minutes to install. Pic provided. I'll post my results when I can.
looks good now you will have to upgrade your holder
B I'm guessing argtek is for the standard /4k wifi models only wonder if will work on professional /advance
yep
Looks great Melvin - please post results- very interested in this mod. Flying the bird this weekend in NY - 59 degrees - cheers all
here is mine with it on
Yea, don't fall for the copper over the aluminum reflector material.
Shape, surface smoothness, and proper antenna alignment (good bracketing)are the most important.
I think pointing your antenna to the right direction is the most important factor with this mod. It is very sensitive even for a 10 degree angle move especially with this kind of distance.
Naturally... the gain is obtained by means of directivity so it will become sensitive to alignment.
But that's after you buy it.
The items I listed were for purchasing consideration.
robvalduga
