What do you do when you lose signal/video turns gray?
I'm wondering what you guys do when you lost signal, and the screen goes dark?
Had that happen to me today as I try to test the limits. I kind of panicked when the screen turned black and white.. And hit return to home until I got the feed back. But that was unnerving.
What do you guys do? And is the a way to push the phantom after losing signal to get the extra distance? I tried playing with antenna positions to no avail.
Grand Rapids, Michigan
Depends on the situation. If I'm flying for range I just keep the throttle all the way forward and see if it comes back.
If I'm zipping around at lower altitudes and lose signal, I hit RTH immediately so I gain altitude and don't unknowingly fly into anything low.
Screen turns black and white .... Pants turn brown ... Hit RTH and clean myself up!
Reactions: Jsun
Happened to me beyond LOS. Map still worked. Manually brought it back.
Sent from my SM-N910T using Tapatalk
Ahhhh! The map! I hadn't realised it still runs. Thanks
Reactions: Javy871
New Threads
CatalinaT
