Well well.
So was the repair supposed to be to your quad, or did they send you back a reman'd unit?
Gerry 1 to Gator 1..... hhmmmmmm
Is the location of your returned unit even close to you or where you fly?
I can't help you with the original unit. Isn't there a serial number, on a tiny sticker underneath the battery compartment of your model?
RedHotPoker
When you received your original quad, is there any clue as to what the serial number was?
when you sent in your original quad, did you have to fill out a form and specify the serial number? Just trying to think of possible ways to identify yours.
I believe RHP is correct as to where the serial number can be found.
Good luck! Hope you find it!
Note name of P3A before shipping back to DJI:
Note name of P3A after return from DJI:
It's a different unit. Anyway to obtain the serial numbers from these logs?
Most likely a refurbished aircraft.
If you upload the .txt flight log file that looks similar to this... DJIFlightRecord_2016-08-13_[19-02-21].txt
I can help give you some detailed info.
Have you looked under the drone, there are stickers the size of a thumb nail. If they weren't removed, your serial number should be included there.
In the Go app, under About, you can read the serial number of the RC. In the app battery section, the battery serial numbers can be read.
RedHotPoker
Here is the file
  • DJIFlightRecord_2016-04-30_[09-35-02].txt
Here is the file
Hope this helps. Did you need any other type of info from this file?
Battery Build Date-12/28/2015
aircraftSnBytes-03Z0847323
cameraSn-04CLAA3H8X
I uploaded a copy of your converted file for you to look over if want. Just extract it.
  • Northern Observer.zip
I looked on the units internal memory and found a host of DAT files collected in February 2016. Attached is the file. At
28.16019747, -80.66453906 it is a flight near Dumpwater, Florida.
Busted DJI
  • FLY018.DAT
jorge sanchez
