Weak RC Signal on Startup
Milan, MI
Just got a new P3A this week directly from DJI. The RC is having trouble fully connecting to the bird. It will connect but I am getting a weak RC signal(2-3 bars). I have to reset the controller sometimes several times before the issue corrects.
I am 99% certain it has nothing to do with how close or far away I am from the bird or how the antennas are pointing? Once the issue is corrected it flies just fine. I am worried that this will only get worse until I can't fly it anymore
1 thing that I noticed is that the bird was named inspire. During the activation process I got several failed activation attempts before it ol went through and when it did it did not correctly give the name to the P3 that I told it to
Anyone else ever have this issue?
If I was you I would ask for a replacement, just in case they used it as a testbed or something, maybe parts or component had come from a different production line. Im sure you are within your rights as a consumer, and I think this thing will just keep bugging you....best to start afresh!
Get it taken care of now while it's new. You don't need issues with anew bird.
Sounds like a plan, just opened a support ticket. Just went and tested out the distance and went 2 miles stock. so definitely just a pairing issue
This morning when I was setting up to fly, I was getting weak tx signal warnings in red and it kept fluctuating between that and safe to fly, changing location didn't help, adjusting antennas didn't help, any ideas? Everything was fully charged.
I never did get my issue fixed although it has never gotten worse or better. I just have to restart the remote sometimes to get it to correct itself. Basically when it isnt working i have 3 bars for the remote. It will never get better and only restarting it fixes it.
Michello
