Ways to get back data from formatted SD card?
Hi all,
I am a new Phantom 3A owner. Just yesterday I formatted my sd card through the DJI app, not realizing that is just deleted the data on the card. I had several videos still on the card. Is there anywhere that these videos would have been saved on the app? Also, is there anyway to restore the data lost? Any help will be greatly appreciated. Thanks!
Josh
Hello Josh. There are several 3rd party apps that you can use to recover deleted data on an SD card. Just do a search for SD card data recovery software.
I don't think you can retrieve a file intact from a formatted SD card. One might be able to retrieve bytes of data forensically, but that won't help you. There should be very low resolution copies of your vid on your mobile device, however, provided you're using the Go app.
If nothing had been save to the card since it was formatted your chances are very good that everything may be easily recovered without any data loss. There a plenty of utilities available that will do this quickly and easily. Ten OP hasn’t told us what operating system he is using so it is difficult to make recommendations.
Reactions: Dronefriend
I am using the Go app. Where can you find the copies of the videos?
I use my IPAD mini for the DJI GO app and fly with it. This is what the sd card was formatted through. Does this help?
Getdataback For PC
Works well on a track 0 delete. Which is all quick format does.
Odds are data is still there.
Paul Caldwell
Do you mean you can use a sd card on your iPad mini? How to you do that?
I think he probably means he formatted the SD card in the bird using the GO app on his iPad
If you do a Quick Format ... which I believe the AC via GO does as well ... then as long as you do not record or defragment / play with the card ... all files are still there. Quick format basically used to just change the first letter of the file name to make it inaccessible to file readers such as Explorer. Near all recovery software will find the files and many will ask you to put the letter back to get the file content.
Files are not lost as long as you do not record or mess with the card before recovery has a chance. That was one of the biggest errors made by Computer shops years ago ... trying to over-write FAT1 with FAT2 to recover ... once done - forget it ... drive is totally ******* !!
Nigel
