Waiting for FC40 to arrive
if its 6 green then bias too big.
need to calibrate.
only 20 confirms home location stored.
need to calibrate.
Ok.
If I do compass calibration and still doesn't achieve home lock what should I try next? Or what's the reason for it not to?
Are you in an open area?
Cajvol94 said:
robinb said:
Probably not enough satellite coverage
So is it possible to get a GpS lock and not a home lock?
They are one in the same, I believe you need a minimum of 6 satellites before a home location is locked. If your not getting the rapid green flashing that indicates a location is locked, it's probably best not to fly in that area. You can take off in ATTI and see if you can acquire a lock a little higher, but I wouldn't advise that.
dlr11164
