ToThePoint said:tizzl10 said:I know the feeling after my mixing up the startup of the app's. Thought it would work but yeah after rebooting => nothingness.
Bear in mind that Rome wasn't build in one day !
Love that quote... and I have confirmed the loss of H3-2D setting after reboot... which is not the fault of the app... it's the Phantom2 Tool or the newer firmware killing the overwrite.... I did some searching and I found where you are supposed to hit the return key on your keyboard to write the H3-2D setting to the Phantom permanently.... but nope... The phantom still clears it out on a reboot...
So ... from start to finish on the same battery this works very well... I flew with it just an hour ago and there is little to no lag at all and the tilt is just as smooth and steady as the app screen control has been...
But if we're gonna lose the H3-2D setting on each reboot then this becomes a little tedious...
so...
to you my friend ocatcr... On to the next fight with this beast... what version of firmware are you running sir? Do you also have to run the Phantom2 Tool for every fresh boot?
Has anybody who downgraded back to 1.08 (or whatever it was) tried this and see if the H3-2D setting will stick...?
Some more reading shows that the Phantom2 Tool may have been killed with 3.0 and that's why it won't survive a reboot...
My philosophy since the beginning...
The app issues a command as it loads to kill the 7th channel tilt via tx... you don't even have to open the camera tab... simply clicking on the app issues the command... Find a way to stonewall that command and we have the golden ticket... smooth tilt control with variable speed and less work to do as we start a flight because it will function properly without all the calibrating.
Kudos to the developer... you are pounding out the codes bro... jumping in here late and pushing out more features than any of the other booster apps in a shorter amount of time... don't pay any attention to the haters calling your app "poo"... it just shows how bad they want this and they will be cry babies when you don't serve it to them on a silver platter in a "dumbed down" version that any 4 year old can operate.... I had fun the past 24 hours sticking with this and figuring things out and flying for awhile today with my beloved 7th channel lever working in all its glory... (cool stuff right there bro)... One step at a time ... and thank you for giving it the effort you have in this short time the app has been available
wishlist
A flight app that eliminates "DJI Vision" all together
This app will contain settings for all the popular hacks ... boost strength ... encryption ... 7th channel camera tilt ... 720p 20fps FPV streaming to full screen size with telemetry and HUD... All included in one app to eliminate DJI control... you will start the app and go into settings the first time and adjust everything the way you like it ... The next time you boot up your Phantom and connect with the app it will inject all your preferences on start up and proceed straight to the camera screen ready for flight...
That's my wish for an app anyway...
If you can produce something like this then you'd be a Phantom hero around these forums...
If you can't produce something like this then stop bitching at this guy who is doing more work and releasing more features for us than anybody else out there... do something constructive and help or shut your face!!
