Vision+ Utility ch7 tilt control
DBS said:
Nice work ocatcr!!
I don't know which new function I'm more excited about... This one or the data logging to csv file...
This app is quickly becoming a necessary P2V+ utility!!
+1
X1 7th channel tilt Usage:
1. Power on both Phantom 2 Vision+ aircraft and range extender.
2. Connect your device to DJI Phantom Vision+ Wi-Fi network.
3. Launch the Phantom2 Tool and set to H3-2D mode.
4. Open Vision+ Utility app, slide the Enable Tilt Control switch.
5. Press Start to calibrate the X1 lever, slide the lever to min and max position and then press Done.
6. Open DJI Offical Vision app, and go to CAMERA mode.
flyNfrank said:
ocatcr said:
all the latest software are installed. but you need to activte the h2-3d setting via https://www.dropbox.com/s/icz90nramn56m ... 2-tool.rar
Mal_PV2_Ireland said:
Working on what software? Waypoints compatible?
What is the process to using the above .rar file? What is needed to getting this going?
Looks like the Android app update went live this morning...
Instructions for the .rar file
https://www.dropbox.com/s/icz90nramn56mf3/phantom2-tool.rar
1 dropbox.com/phantom2-tool.rar
(Download and unzip)
2 connect your Phantom2 Vision to the computer via USB
3 start the unzipped tool you just downloaded.
4 check mark the H3 2d box ( not the vision one)
5 close tool
6 start the Naza DJI Phantom 2 Assistant
7 x1 calibrate and you're done
https://play.google.com/store/apps/details?id=com.taco_rc.visionplusutilitypro
3 Make sure you have already launched the Phantom2 Tool and set to H3-2D mode..
So I'm confused when it's released to the apple App Store what do I need to buy for channel 7 ?
Boost app , utility app or both ?
Just did a little research on this. Looks like the newer Utility app has the boost feature, so the original app no longer needed. I just emailed the creator to get a verification. I wonder if those who bought the first app can get a discount on the new app? At any rate, it's a whole lot cheaper than going the Dronexpert hardware route.
dannytroy said:
I think there is some confusion, considering some users of the Boost app did not know there is also the Utility app.
So do both apps need to run to be able to get the boost, and the channel 7 feature?
The two apps are developed separately, do about the same thing, and are competing with each other.
"FPV Booster for Vision+" (from PVFlyer) is $8.99 on iOS, $8.77 on Android. It's just a WiFi signal booster with no other features yet, but I think they are planning to add Ch7 pitch control soon.
https://itunes.apple.com/us/app/fpv-boo ... 13138?mt=8
https://play.google.com/store/apps/deta ... ster&hl=en
FPV Booster is one touch, one button, no bells and whistles. You tap the button that says Boost Up! and you're done.
The author claims that in addition to simply increasing signal strength it "equips with an interference control algorithm. It boosts extra 50% FPV range with the same Wifi power ... especially in urban area."
I don't know what that means though. Maybe it's changing the WiFi channel to one that's least congested.?
"Vision+ Utility" (from ocatcr) is $2.99 on iOS, $11.60 on Android. It's a WiFi signal booster that gives you more granular control. It allows you to control the TX power on the Phantom and the Range Extender individually.
https://itunes.apple.com/us/app/vision+ ... 18291?mt=8
https://play.google.com/store/apps/deta ... ypro&hl=en
It's not as simple to use since you have to select the range extender or Phantom, one at a time, and manually choose what power level you want to set it at from 4bBm to 20dBm
It also allows you to add encryption to your range extender link to keep out other people.
In addition, the Android version now has data logging so it can record your flight telemetry and the've just added CH7 pitch control.
The iOS version has yet to be updated with the data logging feature or pitch control. Maybe next week. And I'm sure it will be a new (pro) version that you'll have to buy again at a higher price.
For a "do it yourself" method of boosting WiFi power, check out this thread and you'll see what these apps are doing. viewtopic.php?f=27&t=17704
Mori55 said:
I thought they said channel 7 was available today for android and next week for ios ?
People just like to understand that they want to believe. The creator sayed a few weeks, NOT next week.
Still figuring out how to initiate the 7th channel.
I got some result, but it was only from min to max.
No go in between.
Lucas_rc_pilot
