  1. Darknezz
    Hello. I bought my new phantom 4 before few days.
    After a bit confussion about compass calibration, I m now trying small flights in order to learn how to pilot my new drone. However I have noticed that there is no good video transmission in my Ipad 4 (not Ipad 4 mini). The video becomes "pixelized" and it has lag (jurky). Not always but many times. How can I make the transmission more smooth in order to see what i record ? It is very important for me to can see what I 'm recording. Is this problem common ? is it something wrong of ipad 4 or need more powerfull CPU tablet ? any idea is welcomed
    Thank you
  2. CaptainDrone798
    Canada
    Sounds like interference. Are you flying near houses in your neighbourhood? If so, try flying someplace in an open area where there is less interference.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
  4. DroneDestination
    The iPad 4 is not a device DJI thinks is capable of running DJI GO smoothly. If you want a new tablet, the iPad Pro 9.7", iPad Air 2, iPad Mini 4 and Nvidia Shield are all great options.
  5. ryanmanchester
    Do dji endorse the air 1? No issues with it myself
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    They do not. You can see a list of recommended devices here.
  7. jwt873
    Woodlands, MB Canada
    The Air 1 is listed there... I've been using one. It works perfectly. But they don't list the iPad 4.. It might be because it uses the A4 processor and all the recommended ones are A7 and up
    The video end puts a load on the processor and if it can't keep up, you get a bad display. I have an ancient Galaxy 10.1 tablet that I tried out of interest and it can barely keep up.
    #7 jwt873, Jun 16, 2016
  8. Stardog Champion
    Msinger good link. Darknezz.... I smoothed my video by reducing resolution. Low altitude Aerial video seems to be sharp at 1080. This seemed to free up my device (iPad mini4) video processing. Give it a try.
  9. Darknezz
    the tip is to reduce the recording video resolution (for example from 4k to 1080p) or the streaming bitrate (streaming resolution) ? and if it is the second how to do this ?
  10. r62ewa
    Within the Go App you have to click the 'HD' icon and change from Auto channel selection to Custom, then you can reduce the streaming bitrate to 4mbps.
  11. 28wins
    Thankful for this discussion. Thank you all.
  12. Darknezz
    Hello again guys. I tried to change from "auto" to "custom" but i couldn't. Although I can see what you describe I press "custom" but seems NOT to be active (or it is disabled). Is it normal ?
  13. r62ewa
    I've often tried to change my camera settings from Auto to Manual and it seemed like it wouldn't work but I had to touch it in just the right place, something similar here?
  14. Darknezz
    no unfortunately... i tried many times.. touch hard, soft, a bit left or right...nothing. It seems like "custom" is disabled!!!!!
  15. RémyHeli
    r62ewa, adjusting video bitrate for video feed between bird an RC is NOT in camera settings!
  16. r62ewa
    I know. I was providing an example of the same type of slider for changing settings that i found a little finicky.
  17. Darknezz
    and where is it ?
  18. r62ewa
    It is in the 'HD' settings. You have to change from Auto to Custom and then move the slider to the left for 4mbps. That is how you decrease the video feed bitrate, but I believe you say you cannot select Custom still?
  19. Darknezz
    Yes I cannot change from "Auto" to "custom" don't know why... I tried everything. Is it possible some other option in DJI Go to prevent me for doing this change ?
  20. Ron Armour
    Palm Desert, CA
    Did you try a full reset, then see if it allows you to go custom. I did this and it seems to have gotten rid of some flicker I had.
Similar Threads - video transmission smoother Forum Date
Video Transmission To Ipad Mini Problem Since Update 8/2017 Pro/Adv Discussion Aug 11, 2017
Bad video transmission gimbal and camera resets Phantom 4 Pro Help Aug 7, 2017
Latest firmware - FPV Video transmission issues Pro/Adv Discussion Jul 11, 2017
Lose if video transmission Standard/4k Discussion May 30, 2017
P4 stick input - yaw video transmission Phantom 4 Pro Help Apr 24, 2017
