Video distortion
Hello
I recently had a very minor crash however has resulted in some video distortion. I was hoping anyone could shed some light on what was causing it and if possible a fix. Thank you very much. I appreciate the help
Looks to me like your camera/gimbal has a wiggle to it, or the entire bird is shaking badly.
Have you checked your Yaw arm grub screw?
Also, I see an odd "flickering" in the center of the screen (trees) in the 1:26 to 1:40 range. I've not seen that before.
I've watched the drone hovering and can't detect her shaking at all. I've changed all propellers and the plastic fixings holding the the gimbal.
I've seen the thread on here regarding the grub screw but didn't fully understand when it said ensuring it is flush etc. I've checked it though and it isn't loose. Not sure what else it could be
Ok. So the screw is tight. See if the Yaw Arm wiggles where it goes on the Yaw motor (where the grub screw is)
My grub screw was tight, yet the Yaw Arm still wiggled.
Yaw Arm wiggle
jack klausner
