Vagabond Mini to charge P2P
Mesa, AZ
Any photographers out there know if the Paul C Buff Vagabond Mini Li-On (VML) would be able to charge the P3P batteries on the go?
I know it is not designed to run the modeling lights of strobes so I am wondering how the constant draw of the charger would be on it? Here are the basics of the VML
"The system includes an internal lithium battery that arrives connected to the Vagabond Mini™ Lithium inverter. This inverter takes the power from the internal battery and converts it into a usable, 120VAC true sine wave power source. Your flash units are connected to the inverter, plugging into the two standard, 3-prong power outlets (for more than two units, a power strip may be used). The Vagabond Mini™ Lithium inverter includes a multi-level, accurate battery charge indicator and a convenient front panel battery charging connection for the supplied 3-hour universal rapid charger (95VAC to 250VAC charger input). For heavy use, spare batteries can be charged externally so that they are ready to instantly plug in."
tom sauter
