Using IPAD & VR goggles together, is it possible
western australia
Hi All,
With the Phantom 4 I wonder if it is possible to have the Ipad connected up as normal AND VR goggles (for instance using the Samsung s5 + googles) connected in some way.
I have the HDMI module fitted so I am wondering if there is an output on the module that I can use to do this.?
Thanks All
You can connect iPad definitely on USB port of RC. But to connect a Goggle on HDMI port you would need HDMI compatible Goggles. Both will work simultaneously. I do that frequently. You can't use Samsung S5 has part of VR Goggle as it does not have HDMI support.
When I have the goggles hooked up like that I can only see through the goggles is there a way to do both at the same time ? with my Ioad and my DJI goggles? A setting in the DJI go app ?
