TS 832 RP-SMA Use
Mosquito Lagoon and On The Edge
I understand the physical difference between the SMA TX antenna and the RP-SMA TX antenna. If we use the RP-SMA TX with the correct antenna, will it work normally with an SMA RX receiver. I don't see why this would not work if its has the same frequency. While replacing my Fat Shark 250mW TX SMA with the TS 832, I somehow got an 832 that is RP-SMA. I have a RP-SMA CP TX antenna to use. Anyone see any problems before I solder it up.
intertronixlabel
