Travel backpack for P3: Crumpler Karachi Outpost
Just thought i should share this, i was digging up my storage when i found my old camera bag, its a Crumpler karachi outpost, i customized it for my phantom 3 pro and it fits perfect with lots of room. check out the pictures below.
It fits the phantom3, rc, 2 batteries, wires, charger and props and i can fit a 17inch macbook pro, ipad mini and sunshade in the laptop sleeve as well. And there is still alot more space depending on how i customized. The backpack is also very well built with lots of padding.It is compact, great for hiking, carry on, travel- you could bring your p3 anywhere with this.
I DIYed the kaizen foam i got from fastcap.
The only problem is Crumpler has discontinued this model, so it will be difficult to find. I saw a couple on ebay going for $60-100, it use to retail around $300-400
It looks like your motors hit when you put the bag down
The opening is slightly narrow. I normally have to remove the rc first, slide the phantom 3 forward slightly before removing it. I dont think its a issue since the motors sit right underneath the padding:)
Don carlos
