Here’s the skinny!
I did and IMU calibration from a cold start. Put it on the most level surface I could find. My pool table, I did a compass calibration. You know all the usual stuff. Calibrated the TX too, when I’m about 5 to 15 feet off the ground the P3A will rotate in about a 4 foot circle? It will steady out if I climb but it definitely wants to wander when I’m close to the ground.
I usually fly with the VPS off and noticed that if I turn it on it will slow the rotation a bit but doesn’t stop it. I’ve gone to a couple different spots to see if there may be something in my area that’s causing some interference with the compass but with the same results.
I always get at least 17 sats and seen as high as 20 so I’m in a good area for sat reception. Any thoughts from the experts?? J
