Text from update?!
Can someone tell me if it worked or what went wrong?
It says success for V01.04.10 so it is ok.
You had left the firmware package on your SD card with V1.03.20 so each time it start it just check and say that it is uptodate (message "Abort").
So leave this firmware on the sd card for next time?
Log from P3 Advanced updater :
Code:
[00012569]========== remo-con disconnect. boot(15) ============
[00012607]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xb0ce2476].
[00012652]Packet upgrade start...
[00012696]Packet checking...
[00012737]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012777]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012812]Done.
[00012852]Version checking[1]...
[00012934][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013014][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00013066][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00013118][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013235][11 00][00] v1.7.0.0 -> v1.7.0.0 --> Battery
[00013324][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade. --> ESC driver
[00013415][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade. --> ESC driver
[00013515][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade. --> ESC driver
[00013604][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade. --> ESC driver
[00013647][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013724][17 00][00] v1.1.1.7 -> v1.1.1.7     --> RC sections
[00013855][17 01][00] v1.0.2.7 -> v1.0.2.7     --> RC sections
[00013919][19 00][00] v1.0.8.96 -> v1.0.8.96 --> RC sections
[00013959][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade  -->Ambarella A9
[00013997][01 01][00] v1.20.3419 -> v1.21.3647 need upgrade  -->Ambarella DSP
[00014037]Done.
[00016075]Waiting for user confirm...
[00026113]Timeout, start upgrade automatically.
[00026193]Firmware upgrading[1]...
[00041765][01 00] Firmware upgrade start...
[00011731][01 00] Firmware upgrade finished successfully.
[00011773]Done.
Up to you but if you leave it then you don't have to upgrade the firmware of each of your batteries right now, the P3 will do it for you at startup, if needed.
Everything look ok? I tried switching to f but it said I can't run multiple modes at the same time.
From release note, the RC keep same version, so yes, it looks ok.
I have not tried now, the upgrade is for this evening.
Battery and RC don't need upgrade ... thi time.
dlr11164
