Strong interference/RTH
Hi, I'm trying to recover flight logs from ps3 standard.
Each time I take bird up I get about 50m away and it loses signal and starts rth.
I can see bird the entire time so I'm not out of view and antenna is pointed up.
I read where I should try IMU calibration, which I did. As soon as I took off and got going it said weak signal, then signal lost, then Rth initiated. I also have updated to latest firmware.
Any assistance would be greatly appreciated!
Either you are in an area of heavy interference or something wrong with your antenna. Did you ever modify your RC?
Only added inspire 1 mount. I did it just like instructions on here. I was careful not to move any wires. In fact the wires were already out of way of hole.
It also said Strong Interference repeatedly on screen
I always seem to get that message , but it always returns back to normal after... I fear one day it may actually be loosing signal. They really need better firmware right now
There is a app called OOKLA,,its a wifi signal speedtest,,shows if good or bad wifi,,have a nosy:)best of luck,,seems there is a wifi demon about
Reactions: 00kingi
WI.Drone pilot
