Start Litchi mission in the middle?
Is it possible to start a Litchi mission somewhere into the mission plan? For example, specify to start at WP 5 or something, or when you start go to the nearest WP (rather than the first) and continue on from there...
I know it's possible to pause a mission while under way, and then continue. That's not what I'm talking about.
I believe that a mission will always start at waypoint 1 (assuming you are within the maximum allowable distance from the home point and waypoint 1, else the mission won't start at all.)
Reactions: BryanBTX
He is correct! A Mission always starts at number 1.
What is it you are trying to do? If you want to run a subset of another mission you can always save it, then modify as necessary (I.e. delete waypoints 1-4), and then save under a new name.
Reactions: Indiana_pyro
hcashmore11
