Soldering question more than anything else..
I'm not sure if someone knows the real answer to this..
I need to do some soldering to the Phantom board to install the Zenmuse Gimbal. But this is a soldering question.
I just bought a Wella soldering station that says 'lead free ready'. I think the soldering iron's tips have been 'pre tinned with lead free solder'.
Anyways. Does this mean that my soldering tip should ONLY be used with lead free solder? Do I need to buy different soldering tips if I want to use solder than contains lead? Am I meant to change tips here for every solder job if it's switching from LEAD FREE to LEAD?
-Frank
Don't try to overthink it. You'll be just fine using it like it is. The different tips are just sizes. you'll be doing
a lot of getting extra, or dirty solder off the tip, on the wet sponge, and afterwards re tinning , and repeating over
and over again..... ;)
Jerry P
