SMA vs. RP-SMA
they are asking you which plug you want on the antenna's
Hi, looking at the picture above,
the ones called "plugs" are also called males.
the ones called "jacks" are also called females (having an external thread)
so sma male has a pin, rp-sma male has a hole in the center
sma female has a hole, rp-sma female has a pin in the center.
RP stands for Reverse Polarity
so a female with reverse polarity has a pin inside.
a male with reverse polarity has a hole inside.
The image by tferrari is pretty clear. What is your confusion?
This is another version of the table:
No one calls them "plugs" and "jacks" - that's a term from the 1950's.
U are the man. Got it now.
muskansahu
