Simulators
Hi all.
Was thinking that given a phantom plugged into a PC can read the tx easily, there should be some simulator software that allows you to use the standard tx.
Is there anything out there that does?
landwomble said:
Hi all.
Realflight lets you use controllers... But it uses the training port not a USB.
Then again... The real flight controller that comes with the program is similar enough to the standard tx that comes with the phantom that you may not even want to bother hooking up your actual controller.
rockymountaincaptures
