Show off your Cases!!
Here's my version with a P3P that I picked up the other day and couldn't be happier! It's the Ferrari of mobile charging stations that allows you to charge in the field (via car) and at home. One of a kind. Charges an iPad, 3 batteries, and controller all in 35-40 minutes. Has plenty of storage for accessories. Everything is hidden underneath. Has rollers with handle. Best part is as you can see is the fact that you don't have to take the prop guards off.
What brand of case is this?
Reactions: Jack1926
Reactions: ObiDon
Hi guys,
I thought I'd shove up some pics on how I've adapted the cheap non-DJI P3 backpack to carry an iPad Air
So here the case itself, which looks very similar to the DJI OE unit. I don't know if the OE unit is better quality to justify its higher cost, but at circa $50/£30 I think its fine...
Here's the inside of the case. It was at this point I realised there was nowhere to put the iPad.
Then I noticed that the "top" moulding was loose, so I popped this on top of the "bottom" moulding to check how it fits .... I had a thought and popped the iPad on the moulding. I closed the case, just to check if the iPad was trapped between the case and moulding and fortunately, there was plenty of room.
I worked out a final position, then stuck some dense rubberised foam pads around the iPad, using industrial double-sided tape, to trap the iPad in position. You'll note I removed the iPad case...
Here's the finished 10 min project. I decided it needed a larger piece of foam at the bottom, to support the iPad when the case is in use. I'd also found that the straps, designed to stop the aircraft/RC from falling out if you open the case upside down are long enough to hold the whole unit together and hold the iPad in place too. Also, with the iPad case in place, it's just trapped that little bit tighter between the foam pads.
And here is the case closed - just to prove it does! I’ve used this on three occasions now and I can confirm, the iPad hasn’t moved a jot, and is perfectly safe. All-in-all, I’m over the moon!
Cheers... Rob
Which case is that. I am looking for an affordable case that allows you to keep the props on.
This is the kind of case every phantom owner should have so they can keep their props on, less risk of props flying off.
Looks like a Micro Raptor Case to me. I have one just like it with a slightly different foam insert. Search Micro Raptor cases on Amazon. They have a lot of different choices, colors, and foam inserts. I believe they start at around $169.00.
I'm using this B&W type 6000, was available in yellow, black, orange or grey, chose yellow because I already had a sticker in mind as I didn't want to advertise the fact it was a drone, stickering it like this means no one dare go near it lol!
Hi guys,
Cheers... Rob
I just ordered one of those cases from Banggood for $35, great tip on the iPad! can't wait to get the case now!!
MS60
