Self Tightening Propellor Stripped
I got a little too excited landing in wind the other day and had my PV2 tip over. One of the propellors is completely stripped and I can't get it off even when using the wrench with it. I can spin it, but it won't move up at all. I need a way to get the propellor off and I'm hesitant to do anything with the motor so close. Any ideas?
:eek:
try to get a helper to use the wrench on the motor holding it still then you with a screw driver pry up (on the prop) from between the prop and motor while turning it.
You're turning it the correct way, right? :- p
If it's really stripped, it should be reasonably easy to pull off.
Pullers might work, too.
Worst case scenario, you buy a new motor. But I bet it'll pull off with enough force.
I never landed the Phantom on the ground, always caught it.
Once you try it, you will never land it again.
Of course be cautious like everything esle, but it's quite easy.
jumperswaves
