SD Card Format
Discussion in 'Standard/4k Discussion' started by DroneHouston, Aug 18, 2016.
  1. DroneHouston
    My first videos on my P34k with the microSD card that came with the unit played fine on my smart TV. I then bought a new larger GB microSD card and went out and recorded much more. But it was incompatible with my smart TV (LG 4k). When I first used my P34k I was using the DJI Go app on my Samsung note 5 and formatted the original microSD card. With the new larger GB microSD card I used my IPAD Mini with DJI Go app to format. Is that the problem? How can I use my IPAD mini and still watch my videos on my LG Smart TV?
  2. Meta4
    Meta4 Moderator
    Staff Member
    If the format was compatible with your Phantom it should be OK.
    Look at the actual files to see what they are.
    If you have updated firmware, your settings will have reverted to default values and your video will be .MOV rather than .MP4
    I'm wondering if that might be the issue?
  3. 4wd
    4wd
    North York Moors
    (with panasonic TV) I found MP4 plays OK, how you connect it is important - for 4K you need to use the USB3 input and a USB3 card reader or transfer to a USB3 memory stick.
  4. DroneHouston
    I did undergo a firmware upgrade and it was set at .MOV, I changed it to .MP4 and it recorded in .MP4. Still can not play on either my WIN OS laptop nor on my LG 4k smartTV.
  5. DroneHouston
    My USB hub is a USB2.0, maybe that is the issue. But why would it work my original microSD card?
  6. sprite1275
    Is there a preferred format? Mines in MOV and it also will not play in WMP. Although it Will in VCL player.
    Is either format better than the other?
Similar Threads - Card Format Forum Date
Professional SD card format Phantom 3 Help Jul 16, 2017
Can't format sd card on P4P, but can on P4 Phantom 4 Pro Discussion Jun 16, 2017
Format SD Card in Drone from Goggles DJI Goggles Jun 13, 2017
Allocation Unit size when formatting SD card? Phantom 4 Pro Help Mar 26, 2017
formatted card that came with P4P+: mistake??? Phantom 4 Pro Help Feb 15, 2017
