RTH not working, since I installed fatshark fpv
I have a Phantom 1, with a Zenmuse gimbal, gopro black, and fatshark attitude.
Rth was working fine, before I installed the fatshark transmitter. Ruth works, if I turn off the transmitter, but not automatically when the battery gets low. It just drops where it's at. I was thinking that, due to the extra power it's using, I would need to adjust the voltage that it returns home at, but naza assistant won't let me make any changes. Has anyone else experienced this problem?
In Phantoms, RTH doesn't apply when the battery runs low, just auto-land. RTH can only be triggered by turning of the controller or setting the right switch so the lowest position is failsafe.
The voltages you see in the Assistant software are the ones that trigger the LED warning and eventually auto-land. You can't change the final ("loaded") values for voltage, but you can adjust the "unloaded" number until the "loaded" is where you want it to be....the "loaded" values are the only ones that actually do anything.
Jerry P
