- Joined
- Aug 6, 2015
- Messages
- 29
- Reaction score
- 11
- Age
- 59
Water doesn't necessarily kill electronics, water + voltage does. During manufacture, circuit boards are washed with distilled water to remove the flux from soldering, the critical step is drying. I collect and restore old arcade machines, and frequently put the circuit boards in the dishwasher. It's amazing at removing 30+ years of crud and they come out looking like new with no ill effects if properly dried.
If it were my drone, I would certainly be disassembling it, rinsing everything and then drying in a warm oven, and then testing. The motor windings also need attention as they can retain water and fail, although their magnet wire insulation should withstand some moisture. You can use 99% Isopropyl Alcohol to displace water, just don't use the lower percentage formulas if you're trying to displace moisture as they have water as a component already.
Hopefully you'll have a good result at recovering and repairing it.
