Recommended props
Hello, I´m trying to reduce the jello effect and I was wondering if there is a recommended prop better than the original ones. Someone recommend me T-motor Antigravity CF props, but I don´t find any conclusive results, some talk about the original ones are the best.
Thanks!
Your best option is to stick with the factory props... they are much better.
Examine them carefully for any damage and they may need to be balanced with a balancing rod.
Look elsewhere for a jello fix.. such as the rubber dampers etc. not going for CF props or it will all end in tears :)
Thanks both. TeamYankee, which rubber dampers do you recommend? And also, I have a rod that fits into the phantom propellers, but no balancer. Do you recommend some? Thanks!!
Have you tried nd filters? If so, which ones and how strong? And what are your gain settings?
I have a polar pro filter but I don't like to lose some brigthness and sharpness, I would prefer not to use one. I'm going to take a look to the gain settings.
thanks
