Recommended props
Discussion in 'Phantom 2 Discussion' started by janjo2013, Feb 18, 2015.
  1. janjo2013
    Hello, I´m trying to reduce the jello effect and I was wondering if there is a recommended prop better than the original ones. Someone recommend me T-motor Antigravity CF props, but I don´t find any conclusive results, some talk about the original ones are the best.
    Thanks!
  2. TeamYankee
    Swansea, Wales, UK
    Your best option is to stick with the factory props... they are much better.
    Examine them carefully for any damage and they may need to be balanced with a balancing rod.
    Look elsewhere for a jello fix.. such as the rubber dampers etc. not going for CF props or it will all end in tears :)
  3. Meta4
    Meta4 Moderator
    Staff Member
    CF props don't have the give of the flexible stock props .... rigid props aren't going to reduce jello.
  4. janjo2013
    Thanks both. TeamYankee, which rubber dampers do you recommend? And also, I have a rod that fits into the phantom propellers, but no balancer. Do you recommend some? Thanks!!
  5. dptcalvin
    Have you tried nd filters? If so, which ones and how strong? And what are your gain settings?
  6. janjo2013
    I have a polar pro filter but I don't like to lose some brigthness and sharpness, I would prefer not to use one. I'm going to take a look to the gain settings.
    thanks
  7. janjo2013
    My gains are set at
    Basic: 120 120 120 200
    Attitude: 220 220
    Which one do you recommend?
Similar Threads - Recommended props Forum Date
Recommended Brands of Regular or Carbon Fiber Props? Phantom 1 Discussion Jun 24, 2014
Recommended Height and Overlap Surveying and Mapping Apr 16, 2017
Recommended accesories P3S Standard/4k Discussion Apr 7, 2017
Recommended P3S Upgrades Pro/Adv Discussion Feb 20, 2017
Recommended sites for Tampa? General Discussion Jan 28, 2017
