oldengineer said:Is your's an early Phantom, fitted with all right-hand threaded nuts?
...The current versions, have 2 off left-hand threaded motors and 2 off right-hand threaded motors, which logically are always self tightening, rather than the earlier ones, which 2 off, could tend to undo by themselves.
discv said:But that said, the earlier props are keyed/have flats. So provided that the nuts are reasonably tightened and the flats on the prop and shaft are a good fit, I would have thought that they would be unlikely to undo themselves.
But I've been wrong before![]()
oldengineer said:discv said:But that said, the earlier props are keyed/have flats. So provided that the nuts are reasonably tightened and the flats on the prop and shaft are a good fit, I would have thought that they would be unlikely to undo themselves.
...The current ones are also keyed. The keying only stops the props moving (as much) It's the L.H / R.H thread combination that's critical. i.e. the torque of the motor will spin off the nut in a instant (if its not super tight) if its R.H, but needs to be L.H.
discv said:There seems to be 2 types of new prop. One type is as you say. But on the DJI site they show a prop with integrated prop nut with a sculptured spanner to hold the motor casing.
RodVa said:Today I was flying my Phantom and one of the propellers came out. Tnx GOD I't was only a few feets high. I always check them and others things before fly and the nut was tight. This have happend to anybody?
The Editor said:When I unboxed my Phantom from new the very first thing I did was throw away the silver domed prop nuts that came with it - I never flew my Phantom from new with the stock nuts.
Do yourself a favor and get some M6 Nyloc nuts. I bought 20 of them on fleabay for about $5.
You will NEVER have a problem with nuts coming loose again.
The Editor said:RodVa said:Do yourself a favor and get some M6 Nyloc nuts. I bought 20 of them on fleabay for about $5.
