Problem is turned on and then off
Discussion in 'Phantom 2 Vision + Help' started by rogervm12, Oct 31, 2015.
  1. rogervm12
  2. Mark The Droner
    Your Phantom is not turning on and off. It's your battery that's turning on and off. It appears the boot process of the Phantom is failing. But it also might be a bad battery.
    It looks like you disconnected your GPS module. My understanding is the Phantom will not boot up unless it has a good GPS module.
  3. rogervm12
    The battery is new and I try with GPS connected and it doesn't work.
  4. Mark The Droner
    What happens when you remove the battery and try to turn the battery on?
  5. rogervm12
    4 green LEDs light battery
  6. Mark The Droner
    So the battery is good and the boot process is failing on the Phantom.
    Can you give us a recent history of the patient?
  7. rogervm12
    I've changed the chassis and the ESC to the new version 2.1.
    I think the first time I connected the pins from USB to pin M1-M4 of Naza.
    Could this error has burned naza?
    Thanks for all!
    #7 rogervm12, Nov 1, 2015
  8. rogervm12
  9. Mark The Droner
    It doesn't appear you are turning the battery on correctly. It appears your thumb never leaves the battery button.
    To turn the battery on:
    1. Press the power button and then immediately release the button completely.
    2. Quickly push the power button again but this time hold for three seconds.
    3. Release the button completely.
Similar Threads - Problem turned off Forum Date
Gimbal problems Standard/4k Discussion 53 minutes ago
Problem with my New Phantom 4 Advanced plus Phantom 4 Discussion Today at 3:24 PM
Archos 101b Oxygen Android 6.0 connection problem Phantom 4 Pro Help Today at 5:38 AM
Standard I have vision problems and don't have a tablet can you use a lap top computor to see the DJI Go App Phantom 3 Help Saturday at 8:43 AM
Litchi problem Phantom 4 Help Saturday at 8:25 AM
