D
Deleted member 29014
Guest
UNLESS it is an emergency. FCC allows for emergency radio transmissions w/o a license. I have an amateur radio license.Illegal to transmit without a station license from the FCC.
Not correct. You contact ATC or the airport manager to advise them of your intended flight. There is no requirement to ask permission.
You should read the whole paragraph:Sorry again! Since October 25, 1996, the FCC released a Report and Order in WT Docket No. 96-82 eliminating the individual licensing requirement for all aircraft, including scheduled air carriers, air taxis and general aviation aircraft operating domestically.
I own two portable aircraft radios within the last 15 years and there has been no requirement to have a license for these type radios.
http://wireless.fcc.gov/services/index.htm?job=licensing&id=aircraft_stations
Then your local FSDO is making up nonexistent rules.Sorry, but most likely the FAA today is following the recommendations that will eventually become the rule. (according to my local FSDO)
According to the FAA NPRM of Part 107 line 13 of the Operational limitations, it says:
- Operations in Class B, C, D and E airspace are allowed with the required ATC permission.
https://www.faa.gov/regulations_policies/rulemaking/media/021515_sUAS_Summary.pdf
On October 25, 1996, the FCC released a Report and Order in WT Docket No. 96-82 (text) eliminating the individual licensing requirement for all aircraft, including scheduled air carriers, air taxis and general aviation aircraft operating domestically. This means that you do not need a license to operate a two-way VHF radio, radar, or emergency locator transmitter (ELT) aboard aircraft operating domestically. All other aircraft radio stations must be licensed by the FCC either individually or by fleet.Only the station license for radios aboard an aircraft don't need a separate license.
Part 107 rules are not finalized, so they can't be enforced. They don't yet exist. Besides that, Part 107 rules are for commercial drone operations. Hobby flight will still be governed by AC 91-7 which says: "Notify".
I searched for AC 91-7 and I am sorry, but I could not find it.
Any way the FAA has issue an "Interpretation of the Special Rule for Model Aircraft" for the "special rule for model aircraft in section 336 of the FAA Modernization and Reform Act of 2012"
and it basically says:
"Finally, the statute sets a requirement for model aircraft operating within 5 miles of an airport to notify the airport operator and control tower, where applicable, prior to operating.
If the model aircraft operator provides notice of forthcoming operations which are then not authorized by air traffic or objected to by the airport operator, the FAA expects the model aircraft operator will not conduct the proposed flights. The FAA would consider flying model aircraft over the objections of FAA air traffic or airport operators to be endangering the safety of the NAS.
Additionally, we note that following this 5-mile notification procedure would be read in conjunction with FAA rules governing airspace usage discussed below."
This is clear to me.
To read the whole text, please visit here:
http://www.faa.gov/uas/media/model_aircraft_spec_rule.pdf
To answer the OP's question I will provide you with a quote straight from the horses mouth (FAA)...Hi all,
New to the forum and to UAS. I live close to a private airport (very small) and was wondering if the 5 mile rule pertained to all airports or just class A and B airports. Thanks for any feed back.
