Position in map view
Germany
Hi guys,
I've got a strange issue since the last update to 4.1.5 on Android.
If i move the map, my own position is also moving around.
Take a look at the Video below.
I tested this with three different devices with the same result.
Also a reinstall didn't fixed that.
Any suggestions?
Thanks,
Andy
What is the dot on the map showing?
Did you have a Phantom outdoors with GPS reception or just a phone/tablet indoors and not connected to a Phantom?
The dot ist the position of the phone. A red dot indicates that there is bad GPS reception and blue good reception.
In this example here, the Phantom isn't connected but it doesn't matter if it is or not, it's the same behaviour.
When the phantom is connected, its position is also displayed and this is also correct. But the position of phone still behaves like that.
A little update to that issue...
I've played with the various Go App versions and the conclusion is, that this issue exists since version 4.1.4
With 4.1.3 it's all fine.
Can someone confirm this?
apktuti
