Please I need help, servo hookup, please
I have a DJI Phantom and all I want to do is to tap into the stock electronics to control a digital servo just so I can tilt a small FPV camera. I understand how to modify the TX but where in the internals of the Phantom do I plug in the servo so it can be activated by the 7th channel of the TX? Please help, Thank you.
From memory, f2 is pitch (confirm that before wiring it lol) when you open the lid of the phantom, you should see some spare terminals on the naza, the end facing the battery door has the f1 and f2 terminals for the gimbal. The top pin the negative, middle is positive and the bottom is the signal pin.
Hope that helps
Thank you so much, that is what I needed. May all your flights be low cost. I know you know what I mean...
Jesmith1016
