Phantom non-volatile memory type?
Hi,
Does anyone know the memory type/chip model number on the Phantom's PCB associated with the CPU? (or could they send a close up photo of the PCB with the IC numbers visible?)
Thanks,
Serpent
Thanks for sharing.. Do you know if DJI also paints over the IC's on the main PCB board as well as the Naza module?
Thank you CityZen.. interesting information although unfortunately didn't reveal the type/chip number of the on board non-volatile memory.
Actually, that's not true. The MCU on the mainboard is an auxillary CPU that is used for gimbal control and other things. It's a LPC1765FET100, which includes 256kB of flash on die.
The "main" CPU is in the Naza module. It probably includes on-die flash as well. I don't know if there's any eeprom or similar in there.
Johnboy94
