work in progress but i have managed to scavenge left over parts from a phantom 1.5 upgrade...
basically reworked the old v1.1.1 shell to accommodate the multistar 5200mah battery, sunnysky 2212 980kv motors with afro ESCs, and the naza m lite as flight controller. As for the transmitter - i used frsky d8r-ii plus with voltage and rssi telemetry. it is a tight fit with the wires running around!!
i have also put on a dys 3 axis gimbal with the gopro.
AUW without the props is 1400g inclusive of the 5200mah 3s lipo - i will be using 9x4.5 HQprops (APC style) which is in the mail.
I can probably lose some more weight by trimming the wires and soldering rather than using 3mm connectors. I might use lighter ESCs to shave some more weight! the DYS gimbal is also quite hefty but it does work fairly well in getting stabilised video (second to the h3-3d imho!)
check out the pictures
so far all the electronics works ok, though the motors are not as smooth as the DJI's - i can feel some vibrations as compared to the phantom which is essentially vibration free. will take it out for a spin when the props arrived, and see how it flies!
