Phantom 4 atti problem
I have a 2 day old phantom 4 pro turned on for the first time yesterday and did updates with some issues got stuck during update and I contacted dji they told me to turn it off and try again so today took first flight and no problems went to 400 feet with no issue put a good bit of distance on it flew it in p mode and s mode landed then charged battery after charging was done took a second flight and at first all was well but then I switched to atti mode and went to fly away and after about 75 feet it stopped then I tried going up and at about 125 feet it said max altitude reached and also acted like it went back to GPS mode it was holding its position so I refreshed the drone firmware and downgraded to the last firmware for the controller has any one had this issue I am going to try again tomorrow
Don't downgrade the RC firmware back past what the aircraft can interface with. If the RC can't link with the aircraft you'll need to update the RC firmware again.
Are you logged into the DJI Go app? If you aren't logged in with your DJI account they now limit the distance you can fly with the drone. Log in and that should go away...
Another thing to check is Beginner Mode. It's in the settings where you change multiple flight modes, obstacle avoidance etc. Make sure it's turned off.
I checked beginner mode is off and I am sure I am logged into my account and where do you check that and the drone has current update so I was hoping downgrading the rc it would prompt me to update when I turn it on again
