Follow me needs good GPS all the time and you know that every device will have a location for GPS hardware and we should ensure that that hardware has direct access to clear sky. You should use an app to check how many GPS it's seeing. Also never cover the GPS hardware with hand or any metal. Also check if your device has glonass too.Thanks . I know they are not the best but I will still be the one holding the controller while the second device somebody else will have if I can get it to work.
Cheers
An app like this ok? (UAV Forecast) I love it...Follow me needs good GPS all the time and you know that every device will have a location for GPS hardware and we should ensure that that hardware has direct access to clear sky. You should use an app to check how many GPS it's seeing. Also never cover the GPS hardware with hand or any metal. Also check if your device has glonass too.
I never used this app. What do you use it for?An app like this ok? (UAV Forecast) I love it...View attachment 52688View attachment 52689
I use it primarily for wind speed and visible satellites. It also tells me where NFZ,s are. Somebody suggested it so I tried it out. So far I really like it. I got it from somebody on here.I never used this app. What do you use it for?
My point for Follow me mode was that your mobile device should see 10-15 GPS satellites for good accuracy and reliability. I know old devices catch only 3-4 satellites which is not enough.
I absolutely love it!!!UAV Forecast is great! You can set parameters for airports and all, will give you the OK or not if you can fly. As the screenshot above did not recommend to fly because of low temparature... One VERY important, the Kp rating, that can screw up your GPS big time.
I load it every time before a flight in case I missed something.
Kp Index and what it is...
It's called UAV forecast. I don't fly without it! Being kind of new to the site I haven't talked about it much. Didn't want to stand out as "the noob" . I figured everyone had it already . I run the app on android. Unsure if IOS has it or not. It tells us many things including wind speed, number of satellites, and NFZ,s..check it out. Highly worth it..read other posts on here. Apparently others have it tooWhat app is that? looks interesting
It's called UAV forecast. I don't fly without it! Being kind of new to the site I haven't talked about it much. Didn't want to stand out as "the noob" . I figured everyone had it already . I run the app on android. Unsure if IOS has it or not. It tells us many things including wind speed, number of satellites, and NFZ,s..check it out. Highly worth it..read other posts on here. Apparently others have it too![]()
