yes its advanced same as the busted one i have,got it of ebay,been watching utube vids on repairs and seen alot without fansAre you sure it's for an advanced and not a standard?
Yes, some were made with no fan. P3As do not have a fan.got a p3a with busted camera, got a replacement camera but theres no fan on top of gimble,just wondered if some cameras were made without fans and if its ok to use it like that with no fan
See here for more info:- Should there be a fan here?got a p3a with busted camera, got a replacement camera but theres no fan on top of gimble,just wondered if some cameras were made without fans and if its ok to use it like that with no fan
i have p3a and that one as got a fan on, the thing that got me puzzled was that the replacement one had the mounting holes but then all the gimble top plate are the same pro. advan.so i can see what you mean,Yes, some were made with no fan. P3As do not have a fan.
just had a look at my p3a and your right no fan on it, thought it hadThe Advanced does not have a fan, only the Pro has the fan fitted.
So your busted camera has no fan and the replacement camera also has no fan... Problem solved!!just had a look at my p3a and your right no fan on it, thought it had
But it's easy done..... If someone asked me if my P3P had a camera fan fitted, I'd reply swiftly and confidently in the affirmative (I'm sure I must have seen it sometime) .... But the main reason would be because everyone here tells me that it just MUST have one!So your busted camera has no fan and the replacement camera also has no fan... Problem solved!!![]()
