Phantom 2 Vision + or Phantom 2 Zenmuse.
phn
Hi Just wondering which is better?
ie does the Phantom 2 Vision+ have any advantage over the Phantom 2 with H32d Zenmuse Gopro mount?
I guess if there is no advantage and you already have a gopro then the zenmuse version is the one to go for?
Thanks for feedback!
Philip.
Whilst on the surface they're similar beasts they are actually very different in what you can do out of the box.
If you want to take the simple route of just opening the box, charging the batteries and going flying. the P2V+ is probably the way to go. If you want to be able to have a camera which doesn't tie you into a single platform (and there are many other reasons to consider too) then the H3-3D is the route.
I had a P2V and now have a P2 and H3-3D. It gives me far more options and doesn't tie me into DJI if I want to move.
Your best off making a list of essentials, nice to haves and things you can live without and do a pro/con for each. That should help you make your mind up.
Hope this helps
Bmews
Don't get the vision. Per the post above
ODIN Reviews
