Phantom 2 upgrade
I bought a Phantom 2 package several years ago, that included an AVL58 5.8 ghz transmitter paired with an Elvid Skyvision monitor with built-in receiver.
I also got the hard case with custom foam insert.
I used to fly it with a Gopro Hero 4, which I still have.
I modified the controller to move the tilt from the lever on the back to a knob I added on the front. I bought a nicely designed hard plastic mount from a guy in England that attaches to the top of the controller, and onto which I can screw the Elvid.
I haven't used this rig in over 3 years but will need one for some shoots in Mexico later this year.
My question is, which if any of the above components if still functioning, would be compatible, if I choose to upgrade to a Phantom 3 or 4? (I know the batteries won't be.)
What about the spare prop blades?
Thanks for reading!
which if any of the above components would be compatible, if I choose to upgrade to a Phantom 3 or 4?
RC accessories would only match Ph3 Std, and that's barely an upgrade.
Hard case - not completely sure, but I think it might match.
Useable for Ph3, though DJI says you can't use them. That's because of metal thread, which tend to unscrew with Active Braking.
I'm using these sometimes; but you must screw them extra hard to make sure they won't detach.
Reactions: KachemakDiver
Thanks for the fast response. Have there been any developments since 2015 that would prevent me from using the Phantom 2 I bought then? I know a newer model would have many advantages, but I'm just a part-time pilot shooting stills and occasionally video largely for my own use. I was happy with the results I got with this rig and the Hero 4 I flew on it up until 2017, but I haven't flown it since then.
Are there any firmware updates I should know about?
Thanks for any heads up you care to mention.
If the P2 still works swap the camera to a Hero9 since you did the mods with the controller. Resale value would not he worth very much, and upgrading to a P4 or Mavic 2 is pricey and you dont get the cool screen.
Reactions: chascoadmin
hirehackers
