P4P white battery called 'broken'
With a white P4P drone I bought for replacing my broken landing gear I also got a battery charger, a battery and a camera unit. That drone has had a crash as 2 motor arms were severely damaged. Since then I also found that the vertical camera arm is a bit out of line with the gimbal. So the crash will have been hard.
The battery worked, charged well and powered my other drone. But not any more. The system is now calling it a bad battery. It still reports the cell voltages and these are not very much out of sync, but the report says 2 cells are broken.
Voltages : 3.98 - 4.15 - 4.20 - 4.21 16.49V 24C
In my opinion these voltages are not that far out of line.
My other batteries are normally within 0.02 V, these are 0.2 V apart.
Is this the software calling a useable battery bad or is this cell-difference indeed bad enough to toss the battery (or try to recharge the cells individually).
Thanks.
sansuciboy1
