P3P Battery led light 1 blinks 3 x during charge, won't charge?
Have you tried turning the battery on (out of P3) and then attaching the charger?
i battled with this the other day, eventually came right. if the battery is flat it will take a while to trickle charge, leave it on for a few hours. then unplug, Switch the battery on. and then plug in charger. i think i thn pressed the button and it started to charge.
Hold in the power button for about 5 seconds, all the LEDs should light up. If less than 4 light up you have an issue with the battery.
