P3P 1080P 60 fps missing and also 2.7 option missing
Hello,
I had a P3A before which did 1080p at 60fps. I just got a P3P and the for 1080p it only shows 50fps available. Does anyone whats up with that?
P3A also has 2.7K. Whereas on the pro i only see 1080 or 4k options. Is there a way to set resolution to 2.7k?
Hello,
Not on the Pro .. it has 4K and the Advanced gets 2.7K
Since when has the Pro not had 1080/60? I know it doesn't do 4k/60 but I'm fairly certain it can do 1080/60. @alirz, make sure you have NTSC selected. 50fps is the ceiling in PAL.
Phantom 3 Professional
  • UHD: 4096x2160p 24/25, 3840x2160p 24/25/30
  • FHD: 1920x1080p 24/25/30/48/50/60
  • HD: 1280x720p 24/25/30/48/50/60
Phantom 3 Advanced
  • 2.7K: 2704 x1520p 24/25/30 (29.97)
Reactions: Reed L
Thanks. good point. I had forgotten to look at the NTSC/PAL thing this time around... Will check when i get home. Im sure thats what it is..
robvalduga
